Erro ao renderizar
    561 Views Posts
    • #34011
      Boa noite galera,
      minha namorada foi renderizar um projeto e deu o famoso erro “we have encountered error(s) while trying to render phease check the error log”.
      Então olhei o error log, mas não consegui entender o que os erros significavam, alguem pode dar uma olhada? Valeu!
      =========System Information=========
      platform = win32
      country = Brazil
      language = Portuguese
      About to make our qapp
      after make qapp
      Made it after UIManager.initialize
      C:ProgramDataASGVISPython26Libsite-packagesFtXmlInputSource.py:346: DeprecationWarning: functions overriding warnings.showwarning() must support the “line” argument
      FtWarning, 2)
      FtWarning: Creation of InputSource without a URI
      Entering renderArchive
      About to start readArchive – C:ProgramData/ASGVIS/VfS/current_skp.xml
      Traceback (most recent call last):
      File “C:ProgramDataASGVISPython26..VfSASGVISvrayrender.py”, line 288, in initFromArchive
      readArchive(filename, self )
      File “C:ProgramDataASGVISPython26..VfSASGVISarchiveRead.py”, line 145, in readArchive
      asset_parser.parse( filename, asset_read_callback)
      File “C:ProgramDataASGVISPython26..VfSASGVISarchiveRead.py”, line 124, in parse
      print >> sys.stderr, traceback.format_exc()
      File “C:ProgramDataASGVISPython26Libcodecs.py”, line 686, in write
      return self.writer.write(data)
      File “C:ProgramDataASGVISPython26Libcodecs.py”, line 351, in write
      data, consumed = self.encode(object, self.errors)
      UnicodeDecodeError: “ascii” codec can”t decode byte 0xe7 in position 221: ordinal not in range(128)
      File “C:ProgramDataASGVISPython26..VfSASGVISvrayrender.py”, line 413, in renderArchive
      self.initFromArchive( filename )
      About to start readArchive – C:ProgramDataASGVISPython26Libsite-packages/MaterialPreviewScene.xml
      0.352000 seconds is how long it took to read C:ProgramDataASGVISPython26Libsite-packages/MaterialPreviewScene.xml
      0.042000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
      (to ensure this process goes as quickly as possible, please be sure all references to external texture files are correct prior to rendering)
      0.047000 seconds is how long it took to add the plugins to our renderer
      0.002000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
      0.017000 seconds is how long it took to add the plugins to our renderer
      File “C:ProgramDataASGVISPython26..VfSASGVISOptionEditor.py”, line 132, in onSaveOptionsTriggered
      self.saveOptions()
      File “C:ProgramDataASGVISPython26..VfSASGVISOptionEditor.py”, line 164, in saveOptions
      if ( len(filename) > 0 ) and ( filename != None ):
      TypeError: object of type “NoneType” has no len()
    • #34012
      Cara, as coisas não funcionam assim…
      Se apresente no forum antes, complete seu cadastro, leia as regras…
    • #34013
      Cara, foi mal. Mas é que é urgente :/
      Mas vou ter o maior prazer de continuar participando no fórum depois.
      Bom, por enquanto, apenas uma pequena apresentação:
      Meu nome é Wagner, tenho 21 anos e estou no 5º período de Eng. Civil. E minha namorada está se formando em Arquitetura esse ano.
      Estou pedindo a ajuda de vocês para que ela possa renderizar o trabalho de Interiores para a faculdade.
      Obrigado
    • #34014
      Problema resolvido.
      Pra quem estiver com o mesmo problema, eu usei as ferramentas de Debugging do V-Ray e deu tudo certo.
      Obrigado por nem tentar ajudar RogerCar.
    • #34017
      Cara, algumas coisas a gente sabe, outras não. No seu caso infelizmente não fui capaz de ajudar, e achei melhor nem mesmo arriscar…
      Mas de qq maneira o q importa é que vc conseguiu resolver o seu problema.
      abraços
