VRAY 1.6 BETA – problema com aço escovado
    653 Views Posts
    • #69486
      Amigos, ao importar uma textura .vismat de aço escovado com este novo vray (objetos primeiramente tornam-se em preto na cena), o resultado ao renderizar não se concretiza da mesma forma como no vray anterior, ficando uma cor mais escura, imprópria. Alguém sabe do q se trata? Obrigado desde já!
    • #69489
      Posta uma imagem para podermos entender melhor sua duvida crisjohann..
    • #69496
      Crisjohann,
      Ontem foi lançada uma nova versão do V-Ray Beta. A Chaos está chamando de 2.0.
      Segue a lista de correções e modificações:
      • Resolved an issue that caused geometry to vanish when editing a scene during a V-Ray RT render.
      • Transitioning between perspective and parallel cameras while rendering with V-Ray RT no longer causes the rendered view to get stuck in parallel mode.
      • When V-Ray RT in OpenCL mode fails to setup on OSX, V-Ray will revert to CPU mode without a crash.
      • Resolved crash in RT CPU when VRayBRDF has both fog and translucency turned on.
      • Improved stability of RT GPU.
      • Skp2Sided material now supported with RT GPU.
      • Opacity and other float textures render properly in RT GPU.
      • The standard material pays attention to the Default Displacement override / Use global parameters.
      • Our Standard, Skp2Sided, Toon, and Angle blend materials check and correct invalid (negative or infinite) colors.
      • The VFB stays on the top of the SketchUp window in OSX.
      • RGB/Alpha channels are always the first two channels in the VFB and are above other custom render channels.
      • The VRayBRDF layer gets used for viewport representation in our LayeredBRDF.
      • V-Ray diffuse color is no longer incorrectly overwritten by SketchUp material color in some cases.
      • Resolved an issue that caused light cache retracement to always be off regardless of the checkbox in our UI.
      • Resolved problem that could cause default options to be loaded instead of the serialized scene options if you open a model by double-clicking on it rather than doing File->Open.
      • Our Options Editor no longer becomes empty when trying to use render presets.
      • Resolved an issue where DR Nodes could intermittently stop contributing. This fix is part of the spawner itself, so you must reinstall it.
      • Resolved “Ghost windows” from happening on OSX.
      • Materials ending in the number “0” now load properly.
      • Resolved an issue that would prevent copy and pasting objects between models, or automatically undoing the last operation while copy and pasting between models.
      • Unicode paths are now supported when referenced from within lights – IES file paths, for example.
      • The physical camera matches viewport FOV.
      • Focus distance is set correctly and DOF render properly with the physical camera.
      • Resolved issue that caused VRayBRDF to be unresponsive to changes made in SketchUp material editor.
      • Materials no longer rename themselves after making edits in the SketchUp material editor.
      Você pode fazer o download no próprio site da Chaos, por esse link:
      http://newsletters.chaosgroup.com/rdr/75726c5f69643d333333363633266e6577736c65747465725f69643d33313326656d61696c3d64616e696c6f253430746f74616c6361642e636f6d2e6272
      Talvez, resolva seu Problem.
    • #69560
      Tem alguma ideia de quando vai ser lançada a versão final? Obrigada 😉
      Essa nova versão tá muito boa! 😀
    • #69698
      Obrigado, amigos!!
    • #69706
      Parece que tiraram o 2.0 RC do site. Alguém que baixou tem a instalação para me enviar?
      Atenciosamente,
      Portal SketchUp Brasil
    • #69709
      Eu visitei e realmente não tem mesmo =/ . Só o antigo !
    • #69796
      fabvon escreveu:
      Alguem tem a versão RC pra passar???
      Obrigado
